Results 1 to 14 of 14
Thread: Putting Your Pump and Filter In A Shed
    Hey folks,
    I am redoing my pool area and had plans to move my 8X8 shed to my equipment area. I'd then have my equipment inside my shed. Figured it would look nicer and cut down on noise.
    Just wanted to make sure that this is in fact safe to do. Shouldn't cause any issues for me, right? Wasn't sure if the pump had certain airflow requirements that the shed would block.
    Only cause of concern that I can think of is that if the pump or filter has any minor drips/leaks by one of the connections, I could potentially rot out the floor. But I figure I'll just plan for that situation in some way.
    Any other reason why this may not be a good idea? Again, any airflow issues? Is this common?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Putting Your Pump and Filter In A Shed
    I have mine in a building. It does heat up the area, but not bad. I put a ~10X12 vent in the wall right at the back of the pump. I had planned to add a vent up higher, but haven't had the opoortunity yet.
    Cool! Thanks! Did you do anything special to handle minor leak issues, or anything else?
    Aug 2008
    Conway SC
    102
    A friend of mine used a Washing Machine Tray that they sell in Home Depot or Lowes. He drilled a hole in the floor for the drain.. Works great..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    Nice idea! Thanks!
    Jan 2009
    Cupertino, CA
    1,966
    My stuff is in a shed on a concrete pad, so drips aren't a concern. The shed definitely helps with the noise. Previous owner's only caution was that I should leave the doors open if I turn on the gas heater (which I've done maybe twice).
    --paulr
    BBB "Intermediate Swimmer"
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I have a customer that has a sealed room for their equipment and it can get to I'd say around 85 in there during the course of a week from the heat produced from the motor. In other words I would have some time of venting system. I would definitely use a concrete pad or stone for the floor because the water will rot the wooden floor. If you do get a concrete floor have them put in a drain.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by X-PertPool
    Hey, Kevin, my uninsulated garage w/two 16x4" vents (just above floor-level) heats up to well above 100 degrees F. during summer afternoons... 105+ if I forget to leave the side door open!
    Would it be considered a thread hijack to ask if anyone has tried to enclose an existing equipment pad (poured concrete)?
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Apr 2008
    Central Texas
    326
    Quote Originally Posted by PaulR
    --paulr
    Paul, is the exhaust from your heater vented outdoors or does it just dump out of the top of the unit, into the shed? It should be vented outdoors through a vent stack, to prevent carbon monoxide from building up inside the shed.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by HarryH3
    --paulr
    No vent, it's just sitting there inside the shed. I basically never use it. If it isn't on, there's no CO to worry about.
    --paulr
    Apr 2008
    Central Texas
    326
    Just don't venture in to work on the pump or something while the heater is operating. (And yeah, I understand about never using it. My sister has a natural gas heater on her pool and has used it about 3 times in 4 years. The cost is just too extreme!)
    Polaris 280
    Interesting stuff! Thanks everyone!
    Do you guys think it would be safe to have an electric heat pump in there? What kind of clearance do you think it needs? This is an 8X8 shed.
    Thanks!
    Apr 2008
    Central Texas
    326
    Heat pumps need LOTS of fresh, outside air to operate properly. You shouldn't block the airflow around the condenser or over the fan. I would put it just outside the shed and plumb through the wall for the water flow. Just like you see central a/c or heat pump systems installed.
    Polaris 280
    D'oh...Shed couldn't be moved. We lifted it slightly on the skid steer but the floor didn't look like it would hold up.
    Looks like I'll have to build one next year.
