- Apr 23, 2008
- 342
Hey folks,
I've got 8" aluminum bullnose coping around 18X36 IG Vinyl Pool. To remove it and replace it with stone coping (which I'd like to do, I have to first remove it and replace it with track coping, which the stone sits on top of. This is going to run $1,500. But I just found out about "Remodel Coping". Basically it's an L shaped coping, which is meant to be placed right on top of your existing aluminum coping.
You can see it at the following sites:
http://www.tricirclepavers.com/products ... delcoping/
http://www.navastone.com/site/sub/overv ... ategory=53
http://www.travertinewarehouse.com/prod ... oping.aspx
So, my question is....Has anyone seen it or worked with it? If so, how does it come out? Can you tell that it's an overlay? What's your thoughts on it?
Thanks!
Thanks!
