Thread: Anyone ever use or see Remodel Coping?
    Hey folks,
    I've got 8" aluminum bullnose coping around 18X36 IG Vinyl Pool. To remove it and replace it with stone coping (which I'd like to do, I have to first remove it and replace it with track coping, which the stone sits on top of. This is going to run $1,500. But I just found out about "Remodel Coping". Basically it's an L shaped coping, which is meant to be placed right on top of your existing aluminum coping.
    You can see it at the following sites:
    http://www.tricirclepavers.com/products ... delcoping/
    http://www.navastone.com/site/sub/overv ... ategory=53
    http://www.travertinewarehouse.com/prod ... oping.aspx
    So, my question is....Has anyone seen it or worked with it? If so, how does it come out? Can you tell that it's an overlay? What's your thoughts on it?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    87GN's Avatar
    Sep 2009
    Poughkeepsie, New York
    3
    Re: Anyone ever use or see Remodel Coping?
    Can you post pics of your existing alum. coping?
    20 X 40 IG Vinyl Pool, Hayward Perflex EC65A DE Filter, Hayward Super Pump SP2610X15, 1HP fixed speed AO Smith UST1002 C48K2N143C1C Motor, 2 Skimmers 2 Returns, main drain, 1977, 8ft diving board, TFTest Kit, Intermatic T104 Mechanical Timer, SWG Hayward AquaRite T-Cell-15, Polaris 380 Pressure Cleaner w/Polaris PB4 Booster Pump 1997
    Sure:
    May 2014
    Lancaster, OH
    9
    Did you ever install the remodel coping? If so, what was your experience and how did it turn out?
