Thread: My ladder is the source of my algae problem!
    DonW's Avatar
    Jun 2008
    Central IL.
    Getting ready to close the pool in a couple of weeks and I'm starting to get things in order for the close. I've had recurring algae issues and kept my FC level at the high end now for awhile, (9ppm). Water has been crystal clear and since switching over to the BBB way of doing business have been very happy with the clarity of the water, except for the algae. 2 types--Wall clinging green & yellowish/greenish bird-like droppings. Not horrible but fairly constant. Have gotten a pretty good beat-down by it this year and was looking forward to closing as the summer was crappy also. So I go to pull the ladder and carry it to the driveway and was shocked and amazed at the green crud that started to come out of all the nooks and crannies of it. The ladder was LOADED with green swamp water! It's your standard white plastic above-ground pool ladder, with numerous weep holes in it, to harbor algae! OMG! No wonder I've had such a time brushing, shocking and more brushing. I would always brush the ladder whenever I brushed the pool as the ladder would have a light green film on it. Now I know why. I've often wondered if the ladder was the culprit and now have disgusting visual proof. Right before switching over to the BBB method I let the chlorine level drop to zero. My fault. I'm thinking that was the springboard for my summer struggle. Now I'm in the market for a new ladder. The particular design of this one in my mind is one that I won't choose in the future, but I guess one could say that in a properly sanitized pool that this would never happen! I'm hoping that in the couple of remaining weeks that the pool will remain open, I'll see a marked decline in my current algae situation.
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    Re: My ladder is the source of my algae problem!
    What a disappointment!
    And... a relief (now that you've identified the culprit)!
    I've read elsewhere on this forum that ladders can be a enclave for hidden algae. Here's to next year, a new ladder... new water and lower chlorine levels with no algae!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Sep 2009
    Gulf Coast Florida
    Algae is also found in a light nitche. especially if the pool is concrete and the plaster guys didnt wipe it out. pull the light out and wave some water in there to clean it out a few times a season.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist $600 w/part of deck included), 13,500 gallons, Intex SWG, solar panel
    My backyard is like a park... Why then does DH always want to go camping??? I just don't understand.
