Thread: Flapper in skimmer
    Flapper in skimmer
    Has anyone ever had the problem with the Flapper thing coming off inside the skimmer.....Mine stays in place when calm, but as soon as people start swimming and making waves, the thing comes off its hinges.....
    When I look at the flapper, it does not look worn where it connects to the skimmer, almost as the hinges in the skimmer are worn.....
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Flapper in skimmer
    I've never seen any wear on mine. Sometimes people sand them down to allow free movement, but surely nobody would have sanded the skimmer instead of the weir.
    22,553
    Mine comes off also but just on one side. The channel on that side is loose. My plan is to remove the weir and heat the channel and fix (bend) it around a smaller rod and let it set. I haven't done it yet but that's the plan when it gets bad enough to tick me off real good.
    Dec 2009
    7
    Get yourself a Wonder Weir, made by Purity Pool. Should be able to pick it up at any pool store for <$40.
    They're made of styrofoam, and are universal (cut to fit).
    They work especially well in systems with low suction/flow, but the dual blade design is awesome. I recommend them to all of my customers when a weir gate issue comes up.
