Thread: The dangers of cyanobacteria
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    From the Boston Globe. I don't know if this also applies to pools, but since swimmers like to swim everywhere, chances are you may dip in a contaminated pond. FYI and be careful.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: The dangers of cyanobacteria
    One would hope that whatever cyanobacteria happen to fall in or develop in pool water would be sanitized/oxidized by appropriate levels of hypochlorous acid. Eeewh.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    To clarify, the article says that cyanobacteria is often misnamed blue-green algae. Cyanobacteria IS blue-green algae, the stuff that grows in our pools if the chlorine gets too low.
    Really? I recall cyanobacteria from fish tanks as a sticky, filmy sheet of blue-green that stinks. Very different from ordinary green algae.
    Mar 2007
    San Rafael, CA USA
    12,082
    Cyanobacteria is also known as blue-green algae though it is technically a bacteria and not a plant. Because it uses photosynthesis it acts somewhat like algae. Some forms can do nitrogen fixation so can use nitrogen gas as a nutrient (instead of nitrates).
    Green algae is different and is a plant, not bacteria. It is green algae that is the most common kind found in pools.
    Sufficient chlorine relative to Cyanuric Acid (CYA) will prevent the growth of either.
    SW Indiana
    9,199
    Quote Originally Posted by anonapersona
    The film on top with a blue-green algae bloom is composed of the dead cyanobacteria. Yes it is different from green algae, which is a true algae. "Black algae" is a form of cyanobacteria, and the cyanobacteria that are known as blue-green algae are found in the soil and air virtually everywhere. I believe that the BG algae prefers the water to be stagnant, which may explain why green algae is more common in pools that haven't been abandoned or neglected completely.
