Thread: Sand Filter Question
    Sep 2009
    Houston, TX
    117
    Specifically it has to do with this statement in the backwashing instructions in the pool school section
    " First make sure that any valve on the discharge line is open and any discharge hose is rolled out to where you want the dirty water to go"
    I'm not seeing any valve around the filter area. There's one line that runs to the pump, one that runs to the heater and one more that runs in to the ground. I'm guessing this may be where the discharge water flows but it's no guarantee as I just bought the house. Is it possible there is no valve or discharge hose and it just goes to the ground through the piping?
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Sand Filter Question
    Welcome to TFP!!
    The line you're talking about is almost certainly the backwash pipe Just be sure the valve (if there is one) is open before you backwash the filter
    Luv& Luk
    -Ted
    Sep 2009
    Houston, TX
    117
    Awesome. Thanks Waste. I don't see a valve on that line so it looks like it's just moving the multi-port valve to backwash. Any reason that some may have a valve on the discharge line while others don't?
    22,550
    It's probably just preference and if the waste line is connected to a sewer line you'd want to be able to close off that line before removing the multiport for servicing. Also if it's connected to a common drain that may back pressure it, you'd want to be able to close it off. Just a couple of thoughts. Mine runs down the hill so it doesn't have a block valve.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Sep 2009
    Houston, TX
    117
    Thanks Bama. I can't specifically say where it goes as I don't have the original piping layout. All I know is it runs straight down to the ground and from there? Who knows where.
