Results 1 to 9 of 9
Thread: Why aren't there pucks with no CYA?
    I'm certain there is a good reason for this. I just don't know what it is?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Why aren't there pucks with no CYA?
    Welcome to TFP!!
    There are pucks without cya - they have calcium instead
    The reason for the cya or calcium is to give the chlorine something to bond to to be solid (chlorine starts as a gas, and with water can become bleach - but to make it solid, you need a bonding agent - cya is GREAT for this as the tablet formed dissolves slowly - the calcium tabs dissolve much more quickly)
    The real trouble with the tabs is what they use to bind the chlorine - too much of anything in a pool will throw off the balance
    Bleach (liquid chlorine) has the fewest and least harmful side effects, so that's what we recommend using to chlorinate a pool
    Luv& Luk
    -Ted
    See, I knew there was a good reason! Thanks for the great info!
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    So why can't some chemist come up with some inert ingredient to bond it with, so we can use pucks??
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Mar 2007
    San Rafael, CA USA
    12,082
    I am sure there are many that have tried. There is a very expensive powder called lithium hypochlorite (about 5 times as expensive as bleach, chlorinating liquid and Cal-Hypo), but it is fast dissolving and apparently even under compression it does not bind well into pucks that would dissolve more slowly. Even Cal-Hypo in pucks tends to fall apart and has to have binders that don't dissolve readily in water so generally create a bit of a mess.
    There is a product similar to bromine tablets called 1,3-Dichloro-5,5-dimethylhydantoin (DCDMH), but this is normally a powder and would leave DMH behind.
    If it were easy to create a chlorine product that slowly dissolved and didn't add anything that would cause side effects, it would have been done by now. Chemistry just doesn't always give one everything one wants.
    Jul 2009
    London and France
    574
    HTH or one of their many spin off arms make an unstabilised cal hypo puck pack which is fitted into a plastic sleeve and allows it to disolve over a 5 day ish time scale in the skimmer basket, known as the duration tab.
    Maybe useful, I will be getting some of my customers to try them next season.
    30,402
    teapot,
    Where did you read that 5-day longevity? They have been described here before on the forum as pretty useless....generally turning to mush very, very quickly.
    5 days would seem to make them usable.......most reports have seemed to be very unfavorable.
    Jul 2009
    London and France
    574
    Hi duraleigh,
    Sadly from the company rep, so not exactly reliable. faced with the cya problems I thought it worth a try.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Plus, you'd still be getting calcium...
