Thread: Hard water
    Hard water
    I live in the country and have hard water so over time as I have to add water to my pool it is going to raise the hardness of it. My question is does the BBB Method increase the hardness of water more then anything else or is it the best option...? What are the thoughts on this?
    27' Round Esther Williams 52" wall
    Sta-Rite sand filter T-200BP1
    Sta-Rite pump MDL 1G02L 1.5HP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hard water
    The BBB method doesn't have any effect on the hardness. Chemically, it is no different from other pool care. It just involves knowing more about the water and using cheaper sources of the same chemicals.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Hard water
    Calcium hardness would go up if you use calcium hypochlorite as a chlorine source; no other chlorine source will have any effect on hardness. With very hard water you do need to be extra careful about scaling; you want to check the the CSI value reported by the Pool Calculator.
    --paulr
    BBB "Intermediate Swimmer"
    30,432
    Re: Hard water
    Is your water source a well? If so, have you tested for both iron and calcium hardness? What are the results?
    As JohnT said, BBB neither adds nor subtracts from any hardness issues but, sooner or later, you will want to know those numbers if you're experienceing water issues.
    Re: Hard water
    Thanks guys. No issues right now. Just want to stay ahead of the game.
