Thread: Not sure I agree with Plaster Start Up procedure
    Vero Beach, FL
    462
    I had my pool plastered (gem coat by Florida Stucco) on Friday. We filled it with city drinking water from noon on Friday until Saturday morning. The PB said to add chlorine right away, but the start up procedure I found on here said to wait 72 hrs. I did not add chlorine. Well, Sunday we already had yellow algea growing in some spots and black spots started developing. This was despite my brushing and following the other directions. It will be 72 hours tomorrow, so I'll start adding it and the CYA. Anything special I should do?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Not sure I agree with Plaster Start Up procedure
    Most municipal water supplies have chlorine - have you tested your tap?
    Are you sure the spots were algae and not dust/dirt/pollen etc?
    I would add 2ppm at a time - use the pool calc to determine amount. The first day or two without CYA it will be rapidly consumed so check and add bleach a couple times a day.
    Vero Beach, FL
    462
    It was definately algea. It was like a little tuft of yellow hair. The chlorine from the tap registered around 1ppm. However, some of the fill was done during the day with bright sun so it probably was used up quickly. The PB is coming over today to get the CYA up to spec and that should help. I also added a floater for this first month before the SWG kicks in since I can't be at home to add chlorine multiple times a day. It will be nice to have as a backup in case the SWG ever fails or we loose power during a storm. I bought several jugs of bleach too to have on hand.
    Solar heat
    11,969
    Pucks are actually a good idea with new plaster - the acidity helps keep the PH in check and the rising CYA is not an issue since you eventually will have an SWG.
    So are the spots gone?
