Results 1 to 12 of 12
Thread: Builder used too much salt...
    Okay
    So our pool with its new RIver Rok liner was 2 weeks and 2 days old when our contractor decided to dump in 550 pounds of salt. Our pool is probably 10,000 gallons. This is toooo much salt! It was in the water for approx 2 weeks until I bought some test strips and realized his mistake.
    My question.... I presume too much salt can stain the new aggregate liner. What will that look like? Our river rok liner does have areas of differing "color" but how do I differentiate the "break in" of the river rok versus areas that may be damaged by his actions?
    Any thoughts or photos would be greatly appreciated.
    10,000 gallon in-ground pool, Jandy AquaPure 1400 SWG, Jandy Purelink Water Purification System, AquaLink RS Pool Digital Assistant, Jandy Stealth Series Pumps, Polaris 380, 3/4 hp booster pump, DE Filter, Lucayan Blue River Rok aggregate innerds
    Re: Builder used too much salt...
    By the way, the pool chemistry is now correct using the TFP-100 test kit and number match the recommended guidelines established here at this board.
    Mar 2007
    Coastalish 'down easter'
    4,160
    It's OK
    Salt isn't going to hurt a vinyl liner (It's 'plastered' pools that get harmed by salt too soon )
    Does your SWCG unit show 'high salt' and refuse to generate? If not, you have no problem
    Luv& Luk
    -Ted
    Casey's Avatar
    SW PA
    10,453
    Never mind... sorry.
    Jan 2009
    Cupertino, CA
    1,966
    Eh? River Rok seems to be categorized as a plaster/pebbletec type finish, according to maybe a half-dozen sites I peeked at. I think OP's use of "liner" might have been misleading?
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2007
    SF Bay Area
    441
    PaulR,
    He specifically used the word "aggregate".
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Casey's Avatar
    SW PA
    10,453
    I was thinking the same thing in another post he made with pics and then came here and saw he used the word *liner* and then I deleted my message because I *thought* I was wrong.
    I think it would help if the OP would clarify his signature by adding his pool surface...
    I should have went with my gut though and left my message.
    Sorry?
    Does the term "liner" automatically mean vinyl? My original question stated River Rok liner, i.e., river rok is an aggregate "liner". SOrry, didn't mean to confuse. It is an aggregate/plaster ... um... finish? liner? LOL.
    Jan 2009
    Cupertino, CA
    1,966
    "Liner" pretty much automatically means vinyl, at least around here. What you have is a "finish" or "surface." And for pool-chemistry purposes, it counts as plaster.
    --paulr
    Casey's Avatar
    SW PA
    10,453
    Aggregate innerds...
    I'm sorry but that is just funny! It will do.
    Heh....
    Quote Originally Posted by PaulR
    --paulr
    Understood, and have always used chemistry for aggregate. I simply thought that the term "liner" meant any liner for the pool, i.e., vinyl, aggregate, etc....
