Results 1 to 8 of 8
Thread: Polaris 360 tail sponge
    Mar 2009
    Charlotte, NC
    539
    The sponge is shot/ mostly missing.
    What is its purpose? Improve direction/navigation?
    Any sponge I can rig should be OK?
    I see no difference in performance but apparently it is useful somehow?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Polaris 360 tail sponge
    Polaris calls that a "scrubber" and apparently it's supposed to stir little stuff up off the bottom. It has no effect on the performance of the unit. I'd think it needs to be a moderately tough kind of sponge if you have a plaster surface, or it'll get chewed to nothing pretty quickly. If you have a local dealer I'd think the sponge by itself shouldn't cost too much; Leslie's website says $5.89.
    --paulr
    BBB "Intermediate Swimmer"
    That is a tail scrubber. It apparently helps to scrub the walls and sides as the tail whips around. I've gone though several this season. I found a good deal online, I ordered about 15 of them just to make the shipping less important. I also ordered several replacement tires since I've had to replace two of them this season as well. Local prices were 2 and 3 times higher for those items.
    http://www.poolproducts4less.com $4.29 for 3 pack.
    I think it best to replace it before it suddenly dissapears like mine did... I never noticed it in the cart filter, or in the Polaris, or anywhere else. I just hope it did not hang up in the lines somewhere. One may not be an issue, but 2 or 3 might be over time.
    Mar 2009
    Charlotte, NC
    539
    Thanks that is helpful.
    If it is only to “scrub/clean” then that really isn’t important IMO because anything a sponge with essentially no pressure on the plaster can remove is about the same as the water jet that exits this same tail. The difference ought to be negligible. If a sponge was a good idea we’d have other sponge cleaners- instead we have nylon-metal brushes for plaster.
    BTW, you going thru all those parts: don't store it in the sun, perhaps that'll extend the life. And I hose mine off to romove the pool water
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You're right Johnny. Just keep the wear rings from wearing down to the point where the plaster rubs on the sweep hose itself, otherwise you will wear a hole in it.
    Years ago when those first started showing up on new units, my Polaris rep told me that those were for units going into new plaster pools so the tip wouldn't possibly make marks in the plaster. Now I know some of you out there would say that you should NEVER put a cleaner in till X amount of time has gone by. While i don't agree with that, I do respect it, when it is requested. I've put literally hundreds of these units in brand new plaster, and have had no problems, but like i said, I'll never try to talk anyone into or out of doing this if requested.
    Factory Warranty Station for:
    Jun 2007
    North Florida
    79
    That's a really good price for the scrubbers, and I thought I had found good deals on eBay (5 for $9.95)!
    For those of us who are more frugal than we ought to be...before the scrubber material is totally worn thru on the bottom side, you can take off the scrubber and put the non-worn, upper side on the bottom and almost double the life of the scrubber.
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
    It keeps the end of the tail from wearing out.
    15,000 gallon unpainted plaster. Sand filter. Polaris 380.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Pool Clown
    Hm, I'll have to check that sometime. On mine the scrubber never actually touches the plaster--there's a definite up-curve to the tail. Sometimes I've wondered if the tail is too long.
    --paulr
