Thread: Intermatic transformer connection to 12v SAM light
    I am trying to wire an Intermatic PX300 transformer to a Pentair SAM 12 volt light. The wiring diagram that was once attached inside the door of the transformer is gone. From my GFI outlet, I have a black, white, and green wire (110v). On the transformer, on one side, I have two black wires, and one white wire, and on the other side, I have a blue, a yellow and a black wire. So, which wires do I connect to the power side, coming from my GFI outlet, and which wires do I connect to the SAM light cord? And, I think, the green ground wire coming into the transformer from the power side, and the green wire coming from the SAM light cord should be grounded to the case of the transformer? I have searched the Intermatic net site and can't find a copy of the original wiring diagram. Thanks for any help.
    20,000 IG, freeform, plaster, PacFab Mitra 80 gpm cartridge filter,
    1.5 hp pump, bleach, borax, crystal clear water
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    Re: Intermatic transformer connection to 12v SAM light
    I bought and installed an Intermatic PX300 recently. I've attached photos of the wiring instructions that came with it as well as a picture of the transformer itself. I've included the latter so that you can be sure it looks the same as yours before accepting the intstructions as correct. I have no idea whether older "PX300" transformers might be different for some reason.
    Good luck.
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    Thanks a lot. Your transformer looks exactly like mine. I tried contacting Intermatic last week, but they have never gotten back to me. Your photos helped me out alot...exactly what I needed.
