Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Salt Water Systems - info please
    Arizona
    924
    Hi All! I hope you've had a great weekend. I'm so eager to get in my pool, but we've had a pretty cool spring, here in Arizona, and my pool water is just a tad too chilly for me, just yet.
    I'm just starting to do some research on converting my chlorine pool to use a salt water system.
    Do you still need to use chlorine tabs and shock, at all? Or, will a SWCG system be all I will need. I do understand that I will still need acid.
    I've already purchased enough supplies to get me through this year, so maybe by next year, I'll be researched enough and ready to convert.
    I've talked with a pool equipment repairmen about adding a SWCG system and he said to stay away from Pool Pilot and go with I think he said Zodiac. The company that contracts him, though, recommends Pool Pilot. The main reason he says is because of customer service of Pool Pilot - he says they are not good to deal with. I see some of you really like the Pool Pilot, so I'm also curious about your thoughts.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I've ready enough posts by Poolsean, who works for Autopilot, to say that their customer service is probably pretty good!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    East Tennessee
    278
    My 2 cents
    I got pool stored in to Zodiac products ... am not sure about how well there SWG work but if they try to talk you in to a Nature 2 dont buy into their hype of lowered chlorene levels. Waterbear and myself have done the homework on the Nature 2 and have found it is a waste of your hard earned $$$$.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Mar 2007
    Ontario, Canada
    294
    Generally you don't need Bleach (chlorine), but its smart to have some on hand if you want to use it to shock, which in general you don't have to do since your SWCG puts out a constant amount of chlorine, the only times you may want to manually shock is if you have a heavy bather load or on startup. SWCG's have a shock mode but most of us try not to use it to save on the lifespan of the units. As mentioned, there is a tendency of SWCGs to increase the pH, some people see it rise quickly while others see a slow to none increase, I assume it depends on the chemical makeup of your pool.
    Guest
    IMHO, Autopilot systems has MUCH better customer service than Zodiac! We sell both lines where I work so I do not have a bias because I sell one and not the other.
    Not to thread-hijack, but Nature2 is a bad deal. Even if it worked AS WELL as they claim, it cannot save you enough in chlorine costs to to justify itself. Just think: a new Nature2 cartridge is between $90 and $120 and you need one EVERY SEASON. If you spend that much on bleach a season you are probably doing something wrong. So even if you cut your bleach usage in half, the N2 will cost you more.
    Assuming it actually works as well as they claim (but there's no documented proof).
    Stay ahead of your water!
    Arizona
    924
    Great info, so far! Thanks, everyone! I'll definately stay away from the Nature2.
    Buggs
    Guest
    Quote Originally Posted by Buggsw
    Also, If you decide to go with Zodiac stay away from the duo-clear. That is one of their SWGs with a built in Nature 2. their LM3 is a decent unit but I like the Pool Pilot or the Goldline units (AquaRite) better.
    Ft Lauderdale, Florida
    1,455
    WOW... Buggsw, I don't know how to respond to that comment. I will bring this to my customer service manager's attention if this is the perception of the pool contractor. Please know that I am available to assist at anytime, if necessary.
    Heck, I was just in Awatookee (or however you spell that city just south of Phoenix) just a few weeks ago. TOO hot for me and please don't say, "Its a dry heat!". I slow BBQ my pork picnic shoulders in DRY HEAT!! lol
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Arizona
    924
    Waterbear - Thank you - it was the LM3 that the repairman was recommending.
    Poolsean - Thank you, too! I had no idea that an actual Pool Pilot representative was on this board. I love to see vendors participate and not just lurk. I will tell you exactly what he said - that the Pool Pilot company was slow to respond, did not have a good turn around time or a cross ship. He claims that the Zodiac company would cross ship and had pretty much a no questions asked policy when dealing with them under warranty. Out of warranty, they still sent parts and had a quick turn around and were generally easier to deal with. He also left me with the idea that the Pool Pilot broke down more frequently.
    Now, I don't know one from the other - which is why I posed the question. I certainly hope you don't take offense at my post - these are not my opinions, at all. The local pool supply store pushes the Pool Pilot and I'd like to think they wouldn't sell junk. However, I personally have been lead down the wrong path by pool stores and also some so-called experts in the past. When you are paying a high price for a piece of equipment, it's not a joy to have gone the wrong way. Especially, living in Arizona, when a pump goes down or a filter fails or other equipment fails - boy, things can go bad with your pool very quickly.
    Too hot in Ahwatukee, eh? Yeah, we had some unseasonably hot weather a few weeks ago. Thank goodness it didn't last. It's actually been a bit chilly here the past 2 or 3 weeks since that hot spell. My pool water dropped back to 62 degrees. I don't know how you can claim to roast anything in a dry heat in that steam bath of a state you live in. LOL! My folks lived in Ft. Myers for 14 years and my brother lived in Orlando for several years. Seriously, you live in a gorgeous state. I love Florida - but not the bugs.
    Buggs
    Guest
    In the store I work in we sell both Zodiac and Pool Pilot. IMHO, I would take the pool pilot any day. I am not that impressed with Zodiac customer service, especially to the end user!
    1,455
    touche'
    I guess thats why we dont do dry rub bbq down here. Seems like Arizona is filled with former southwest florida residents.
    I can't believe you dont like buggs! I thought thats what your name implied, with the w meaning WOO HOO.
    I took no offense with your feedback. The input is most appreciated and as I said, I will forward these comments to my customer servive manager. The dealer name is not important, the perception is.
    Thanks again,
    Arizona
    924
    PoolSean, ahemmmmm! That would be Buggs as in Buggs Bunny - which was how it was spelled when I was a kid - well, maybe the way I spelled it, anyhow. LOL!
    Thanks so much PoolSean for your concern and professionalism. That in itself is a plus, in my book.
    Buggs
    Toronto Canada
    20
    I've had the Autopilot unit for a few years now. Excellent, trouble-free unit.
    I had a couple of small issues with it that they took care of easily-even though I am in Canada.
    Their customer service is excellent.
    As for Nature2....had it as well. The one season I used it was the only time I ever had an algae outbreak
    Want to buy the "professional" model? lol
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Arizona
    924
    Thanks Hzz. Great testimonial. Think I'll pass on the Nature2 unit, though.
    Buggs
    Mar 2007
    Southwestern Ontario
    51
    My pool had the Zodiac Clearwater LM2-24 unit installed when it was built last season. The LM3 was not available up here in Canada last year, not sure if its here this year either. My unit seems to be working just fine. No problems. Runs even in the cooler water temps if needed.
    I cannot comment on the nature2. My builder did not recommend one of these for us, acually recommeded against the nature2, we trust their knowledge and have had no problems with our pool or build what so ever.
    So from my experience, the LM2 has been great. Down the road we will see.
    I have sent several emails to Zodiac Canada and there have been no problems with getting the responses I needed in a quick and timely fashion.
    Every product may have problems, so take any review or experiences with a grain of salt.
    62,800 Litre IG Vinyl
    Sand Filter
    1HP Super Pump
    Clearwater/Zodiac LM2-24S SWG
    Aquabot Turbo Robot Cleaner
    250K NG Heater
    Arizona
    924
    Caustik, thanks so much for sharing your experience with the LM2.
    Buggs
    Baton Rouge, LA
    237
    Thanks for the comments on diff manfactures...
    In the pool build process right now, and am planning on using the Pentair 4x160 pump, the Pentair Easytouch, and hence, I figured to make everthing "work" best together, also plan to use the Pentair Intellichlor SWCG.
    Any feedback on this unit?
    Any reasons to consider a different one, such as the Pilot?
    Thanks!!
    Steve, who lives in the state with the perfect weather
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    SeanB's Avatar
    Mar 2007
    2,622
    We have the Intellichlor IC40 and have had no issues with it. It's easy to use and does the job. We've only had it for less than a year though so I can't speak to its longevity. It's seems well made though.
    If I were in the market right now though, after having read more, I would take a harder look at the pilot's.
    TFP Founder
  20. Back To Top    #20
    Mar 2007
    Murrieta, CA
    215
    Quote Originally Posted by stevenbrla
    Thanks!!
    This is pretty much exactly what I have. If you're getting the Easytouch, make sure you get the model with the Intellichlor built in. It's much more cost effective than buying a seperate Intellichlor system. This will give you access to some basic diagnostics (salt level and various error messages). It also gives you the ability to control SWCG output in 1% increments. So far, I haven't had any problems with my unit.
    I believe the Pilot has an option for automatic acid dispensing, so this may be a worthwhile option. I've been adding acid almost daily to my new pool.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
