Thread: New pool owner using BBB and basic first pool readings
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Until my Taylor test kit arrives next week (K-2006), I'll have to resort to using the installers supplied test strips. It was filled two days ago, and the pump has been running since then.
    FC 3
    TA 80
    PH 7.8
    I'm assuming these values are OK for now. Can't test CYA, but I asked when they were adding to add lower rather than a higher amount, so he said it should work out to be about 20-30.
    At the moment I'm using trichlor in the chlorinator until I get my test kit and switch to bleach.
    Does it look like I'm good to go for now?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New pool owner using BBB and basic first pool readings
    Yup Keep an eye on the PH - it is a tad high. When your kit arrives retest the PH and then you can decide if you want to lower it a bit.
    flyboy320's Avatar
    Jul 2009
    216
    Thanks frustratedpoolmom....
    The installer told me to watch the PH with the vinyl as it can damage it. Problem is I can't remember if it was high PH that can damage the vinyl, or to low a level....
    11,969
    Low PH - how long of a period that it's low before damage occurs isn't clear.
    High PH + high TA + High CH can cause Scale, even on Vinyl.
