Thread: Sand filter and pollen
    Mar 2009
    Woods of North Florida
    148
    Will a sand filter be able to catch pollen or should I use that stuff that makes small particles clump? The pollen is really bad here. I just brushed my steps a few hours ago and they are yellow again! I'm not sure if when I vacuum and skim the filter is catching the pollen or if the pollen is just accumulating. Thanks!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand filter and pollen
    My sand filter has no trouble with pollen.
    30,432
    Mine neither
    Butterfly's Avatar
    South Carolina
    10,045
    Mine neither
    When we have heavy pollen, the skimmer sock appears to catch most of it.
    You're done SLAMing when:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Try adjusting the return eye a little. The pollen may be collecting on the ladder before it gets to the skimmer. My ladder catches all kinds of junk falling out of the trees!
    Love TFP? Become a
    TFP Supporter!
    Mar 2009
    148
    Thanks for the replies! I feel better now.
