Results 1 to 7 of 7
Thread: Which kind of AG cover?
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    I'm considering either a solid cover or a mesh cover for my AG pool.
    My conditions:
    * moderate-hard winters
    * LEAVES! Oh so many leaves!
    * Rainy springs
    * Many animals and birds using the cover as a toilet/bath in spring
    (* water supply is not expensive here)
    Equipment:
    * a tiny cover pump
    Each year, I scoop out hundreds of pounds of sludge from the pool cover, pump off days' worth of water, and deal with horrendous hatching mosquitoes on the cover. It's disgusting. (And this is after cleaning off the majority of the autumn drop.)
    When I open the pool, it is BROWN. (It may be partly from closing the pool before a 80ยบ October and opening the pool in June.)
    I need a new cover (the old one had several holes), so I ask: what kind of cover would you recommend? I'm looking at these two types, but am open to others.
    http://www.waterwarehouse.com/poolsu...esh-Cover.html
    http://www.waterwarehouse.com/poolsu...ter-Cover.html
    Or maybe this: http://www.waterwarehouse.com/poolsu...esh-Cover.html
    12'x24' Oval Above Ground (Partially Buried)- 7000 gallons (est.)
    SwimPro Sand Filter
    Current pump: Hayward, 1.5 HP, SF 1, 15 amp (soon to be replaced)
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    Re: Which kind of AG cover?
    No takers at all? Has anyone used a mesh winter cover?
    SwimPro Sand Filter
    Jul 2007
    Northern NJ
    299
    Sounds like you really need a leaf cover. That will go a long way towards getting rid of the mound of mucky leaves you encounter in the spring. I have used the solid cover and the mesh cover. I prefer the mesh. If you are getting a lot of rain, the mesh cover will allow the water to filter through and you won't end up having to pump the cover off all the time.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I'm with Nicole. The solid covers are a hassle and the micro mesh covers just eliminate that swamp on top - we've used one for years and it has held up extremely well - no shredding or rips and we freeze as solid as it gets anywhere in the states.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Casey's Avatar
    SW PA
    10,457
    Does the pool water get dirty/murky from the mesh covers when the rain water goes through?
    Jul 2007
    Northern NJ
    299
    Nope. Mine was nice and clear. Just a bit of silt on the bottom, but a lot less hassle than the solid cover.
    Nicole
    21' AGP (10,400g)
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Sounds like Nicole and I have exactly the same experience. Never anything more than a bit of silt - crystal clear water at opening each year. I would never go back to a solid cover.
