Thread: Fas DPD Test residue
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    THroughout the season I have used the TF100 FAS-DPD test quite a bit. There is a black film that has formed on the vial and I was able to get most of it off with just water and wiping it down good. It still looks stained. I have the same black residue over the spoon for powder.
    Can I use MA or something else safely to remove this residue (more concerned about the spoon being dissolved)?
    What is turing things black?
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    30,414
    Re: Fas DPD Test residue
    A solution of 3:1 water to muriatic acid will clean about 98% of it. It's the nature of the beast.
    Jan 2009
    Cupertino, CA
    1,966
    Seems to me I read that straight bleach would also clean it up. I use the cylinder for dosing my spa (usually 10-30ml of 12.5%) maybe that's why I've never observed the problem, despite using FAS-DPD twice a day for the past six months or so.
    --paulr
    BBB "Intermediate Swimmer"
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    I was getting a residue buildup...cloudy looking...so I filled the testing vial with straight 6% bleach and let it soak for a half day or so. Read about it on another thread, with an explanation of why this happens. Cleared it up again. Now I'm rinsing the vial well after testing and wiping it dry inside with a clean paper towel. It's stayed clear since then. HTH.
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
