Results 1 to 10 of 10
Thread: Help please!!!
    Help please!!!
    I have a 15 x 42in soft side pool. The pump quit several weeks ago and as you can guess the water is terribly disgusting. I have not had the money to order another intex pump that is likely to **** out too (seeing as there are a plethora of bad reviews on them) and managed to find a used pump from someone local. Well it quit too. Worked when we set it up and i go out this morning and the motor is running but no water is pumping...so the exact same thing my first pump did. So my question is this........I really don't have the funds available to order another pump........Will the pool itself be fine if I go ahead and drain it and store it dirty over the winter and then when i set it up next spring and hook up a new salt water pump just clean it thoroughly then? I at least shocked the heck out of the water and added a ton of algeacide to it so it's at least not green anymore but it's a really nasty cloudy color. And the mosquitos breeding in it are horrendous so I HAVE to do something about it.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Help please!!!
    Welcome to the forum, and bummer about the pumps.
    I don't know whether it's harmful to store it dirty. But if the water's a mess when you dump it, I think I'd put at least some fresh water back in afterward as a kind of "rinse cycle," at a minimum try to hose down the insides and get some of the crud out, before putting it all away.
    --paulr
    BBB "Intermediate Swimmer"
    Re: Help please!!!
    That's a good idea, Thanks
    30,403
    Re: Help please!!!
    I would guess your pump is fine but your filter is clogged....just a hunch.
    Re: Help please!!!
    It's not. I'm actually smart enough to have checked that Put in a new one and everything. Sadly it seems as though Intex doesn't believe in making a quality product. If you google it, the reviews are horrible for these pumps.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Help please!!!
    Welcome to TFP!!
    If the motor still runs, you can probably salvage it An air leak can cause lack of prime or a clogged impeller (as well as a clogged filter - but you say the cart is new). I'd see if you can't figure out why water isn't flowing through an operational pump before emptying the pool - there are lot's of pump savvy folks here to help you with this
    Luv& Luk
    -Ted
    Re: Help please!!!
    Thank you
    Re: Help please!!!
    ok, so how do I check this impeller thing? Where do I go to ask about it?
    Jul 2009
    Houston, Tx
    19
    Re: Help please!!!
    I have the 2000 gal/hr intex pump/swg and have been more than a little surprised in it's performance. At this point, I would have no problem ordering another, especially at the prices they are being offered for at the end of the season. They seem to have made some improvements in the latest versions of the intex pumps.
    Intex 22 x 52 Ultra frame, 10,400 gals
    Intex 2600 gl/hr sand filter
    Jan 2009
    Cupertino, CA
    1,966
    Re: Help please!!!
    Quote Originally Posted by jennclay6
    Try posting in the Pumping Station area, the motorheads will notice your question.
    --paulr
