Thread: Spa to pool spillover (does this look right?)
    I've been arguing with my pool builder for over a year about the way our spa spills over to the pool. I don't think it is done correctly. They actually forgot to do until after they had poured the shell. They had to break it up and insert the drain tubes. I think it looks very sloppy. But I searched and couldn't find any pictures of this set-up here or anywhere else online. Any thoughts?
    18'6" x 36'6" Grecian In-ground
    27,000 gal. (give or take)
    Sand Filter
    Polaris
    Solar Cover
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Spa to pool spillover (does this look right?)
    It looks very industrial, doesn't it? Hard to say whether it detracts from the overall appearance of your pool without seeing a wider-angle photo, however. If you still have some leverage with the pool builder (or even if you don't) and are very unhappy with the result, insist that the builder re-do it -- and this time, BE THERE to supervise!
    It seems that most builders/buyers like wide-mouthed open spa spillovers; but I chose to have one that is under the coping, rectangular, slate lined and only a few inches above the pool water line, so as to be almost obscure and nearly silent. The spillover in the picture you provided resembles a stormwater diversion from a culvert. Ouch!
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
