Results 1 to 7 of 7
Thread: adding a spill over spa the existing inground liner pool
    SO I purchased a fiberglass spillover spa and need to install it.
    I need detail discription on how to do it. I installed the my pool myself so the spa should be with in reach. The pool has 4 feet of pour concrete around it. I would like the spa to be raise a foot off of the deck.
    Help
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: adding a spill over spa the existing inground liner pool
    Welcome to TFP!!
    I've installed dozens of them on liner pools, but I'll need pictures of your pool and proposed installation spot to give you detailed info There will still be some guesswork involved on my part because I won't be able to see where the pool panels come together.
    You will need to run the pipes back to the filter pad and add some valves so you can have 'spa only' mode, so some pics of the equipment pad will also be needed.
    I can and will help you with the install, but need to know your specific set up to answer you properly
    Luv& Luk
    -Ted
    Do the pictures help, I plan on installing the spa on the left side near the middle. The large oak tree is long gone.
    Quote Originally Posted by waste
    Welcome to TFP!!
    DaveNJ's Avatar
    Toms River, NJ
    520
    What size is the pump (model) and plumbing that is installed now? This may help "waste" in giving you further quidance.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    It seems straight forward. Cut concrete, dig hole, place spa, connect up plumbing test for leaks and fill in new concrete.
    Depending on how many jets you have you may need a second, or bigger pump. Do you have a link to the spa you purchased?
    I half-buried a portable spa next to my AG pool and plumbed it together, including two other pumps(three pumps total), and a separate air blower. I use my solar heater array to heat my spa, and it will raise the water to 137* from 90*(forgot to turn it off and it got a bit hot) in one day of full sun. I also have a Homemade HP and spa pack elec. resistance heat to keep it warm. So I know a bit about plumbing up a spa.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by launboy
    Adam
    Can you get the spa heated this way at night? To around 103ish? This is really interesting. I use my heater but I would never have known you could use the solar array to get it that hot. Impressive!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    No heat at night cuz the suns not shining. But on A sunny day my panels get full sun from around 10:00am to about 3:30pm this time of year up here in WI. And on those days I can end up with 110* water without any trouble. We jump in the water as soon as it's less then 107ish because anything hotter is too hot. Thing is I don't have the spas electric heat hooked up yet so the tub slowly cools as we use it. Kind of a timer for when to get out.
    To get past 95* though you need full sun though. My solar will heat make heat on a cloudy day, but it won't get water much past that point without some good sun at the end of the day. If you have better insulation on your spa then I do you'll be even better off. My spa will drop from 100 to 80ish overnight if the air dips into the 50's. Before winter I'm reinsulating the whole thing though, and fixing the foam in half my cover that's partially water logged.
    To answer your question though, yes, your solar array should get the water to 103* on a sunny day, and depending on the starting temp, and how many panels you have(I only have three 2x20 panels) you could reach that temp in a fairly short time.
    Adam
