Thread: MagnaSweep in floor cleaning system.
    Dec 2007
    St Augustine,FL
    1
    I have a 4 and half year old pool with a MagnaSweep in floor cleaning system. In the last week or so one zone of heads does not shut off completely. The control valve has flapper valve not balls in it. I checked all the flappers and can find nothing wrong. I called A&A manufacturing but they were no help. The guy I talked to, had no clue about the problem. Buy the way, the one part that you would think was repairable( the flappers ) are not replaceable. Any Ideas?
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: MagnaSweep in floor cleaning system.
    It sounds like water is bypassing down that one bank and it is not shutting off correct. most infloor watervalves have a "rebuild kit" available which replaces all the parts in the valve. Its no use just replacing some parts as they all wear the same, so if you replace one part you might as well replace all the internal parts.
    cheers
    malcolm.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
