Thread: Cloudy after Cal-Hypo
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    Im hoping that its normal and that it will clear up again. I was told to sift it into the skimmer and that I did not need to pre mix, even said so on the container.......
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    30,432
    Re: Cloudy after Cal-Hypo
    Yeah, it's temporary.
    A big dose of cal Hypo causes the calcium to precipitate locally but it will even out and be gone by AM. Your prior CH was around 170....correct? What was your most recent pH and TA?
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I tested this morning and got
    FC 20 shock =28 will check this evening and add cal hypo
    TA 110
    CH 120
    3) IG
    5) pump is 1.5hp
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    PH?
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    ooops......PH was between 8.0 and 8.2. is what Im doing able to change the ph.......the ph is probably not accurate due to the high chlorine
    3) IG
    5) pump is 1.5hp
    Butterfly's Avatar
    South Carolina
    10,045
    You are correct. Test pH and adjust (if necessary) when your FC is below 10.
    High FC levels can make the pH read a false high.
    You're done SLAMing when:
