Thread: TF100 kit questions
    Sep 2009
    Prairieville, LA
    18
    TF100 kit questions
    I recently got and have been using my TF100 kit and its great! But while in the process of shocking/testing I've used up all my R-870 powder. I'm using one heaping scoop everytime I test while shocking/testing. No problems at all with the kit but is there something I can buy locally while I place/wait on my order from tftestkits.net? Also, when I'm done with shocking and am able to hold FC overnight, I guess I should be using the ph/OTO kit daily, but how can I read up to a 7 at my current 60 CYA level, can I dilute the sample?
    Thanks
    Jim
    27' round AG, 17,000 gallons, sand filter, 1 1/2hp motor, new BBB user
    30,432
    Re: TF100 kit questions
    Hi, Jim,
    It's pretty unusual to run out of the powder first. Are you using the little rounded end and not the wide, flat end of the blue spoon?
    The idea is to use just enough to turn the soltuion pink....you may be able to get by with less.....just so it colors the solution.
    As for refills. I use Taylor chemistry and it's quite probable you can find that locally at a pool store. It's R-0870....the same number as on the bottle.
    2 work days to ship it to you from NC.
    Good luck.
    Sep 2009
    Prairieville, LA
    18
    Oops, I think I was using too much powder. Thanks for the replies and I'll order some more tonight.
    Thanks from the newbie,
    Jim
