Thread: winterizing pool with Boron
    Have there been any acurate tests recorded with using Borax for a winter pool closure and no oxidizers used? My pool closures typically are Nov thru Mar.
    30K gal vinyl IGP, 1HP pump, Triton Tagelus TA60 sand filter, 60 GPM flow rate, Aquabot
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: winterizing pool with Boron
    The boron product will help stabilize the ph level and reduce eye and skin irritation caused by the chlorine but it is not a sanitizer. You will still need chlorine
