Results 1 to 9 of 9
Thread: Do you have to remove pool stairs?
    Peculiar, MO
    6
    I am new to the pool world, I must ask a question. Do you have to remove the pool stair during the winter? My stair/ladder combination is easily dissassembled, so I am not sure if I need to remove the section in the water for winter. Any comments welcome.
    Self Installed 14,000 Gallon 24' Round AG Vinyl with Hayward 250 lb Sand Filter and 1.5 HP Single Speed Pump.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Do you have to remove pool stairs?
    We have an article in Pool School about closing your above ground pool.
    I believe the suggestion there is that they be removed.
    You're done SLAMing when:
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    All depends on whether you're planning on covering it for winter or not. If so, then you'll need to either remove them completely, or push the section that stays in the water over so it's floating in the pool. FWIW, I remove mine and leave them sitting on the deck. I was always kind of antsy leaving them floating in the pool over the winter.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Aug 2009
    Keene, Texas
    157
    So, even if you leave your pool open during the winter and continue to maintain it, you should still take the ladder out? Or let it float in the water?
    This is the first year that I thought I would actually leave it open and maintain it, since it costs so much less, but I figured I would leave the ladder in. I did not realize that you should pull it out anyway. I am curious what the reasoning is. I figured that you pulled it out because of algae growth, but if you maintain chlorine levels all winter then that is not an issue. So what is the issue with leaving them in?
    Aaron
    amoses (Aaron)
    Converted from Baquaqoo in the fall of 09. Best thing I ever did!!
    AG, 24 Ft Round, 54" wall, 48" deep, 13,500 gal., TF-100 test kit
    Hi-Flo II 1.5 HP pump, AquaTools High Rate 200# Sand Filter AT3120
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    If you're leaving the pool open, then I don't see any harm in leaving the steps in the pool. Of course, I've been wrong before (and twice today so far). Any other opinions?
    Intex 8110 SWCG
    "Fear the Schnauz!"
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    If you are going to cover your pool for the winter, you'll probably have to pull the steps out because the cover will not fit with them in place. If you are leaving the pool open and maintaining, like I am going to do (in Florida, can swim in December at times), then leave the steps in place. No need to take them out if the pool is not covered.
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    Casey's Avatar
    SW PA
    10,448
    I'm in PA and take them out. Too cold to swim. Brrrr
    Jul 2007
    Northern NJ
    299
    My only hesitation about leaving them in when up north is if the pool freezes. It could do some damage to them I would think.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    We technically don't "close" for the winter, but it is too cold to swim. We are able to just run the pump a few hours a day, and when it freezes, and I learned last year that is not enough to make sure the algae does not set up camp in the steps/laddder. It was pretty nasty when we took the ladder out last year, even though the pool was crystal clear and the water was 60 degrees. Hopefully a change in approach this year means it will come out cleaner and require less effort to clean up. Our ladder has a bunch of nooks and crannies- lots of time with a small brush and bleach water to get that all under control.
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
