Thread: Recommended TA levels...
    The TF test kit says TA should be 90-120, but recommended levels on this board for a SWG pool is 60-80, so which is it? I'm at 90 with other numbers good (CH is high, but that is how our water is).
    - Jeff
    15,000 gal SWG pool, cartridge filter, all pentair equipment, variable speed pump, 400K BTU heater and spa, pebbletec finished
    Butterfly's Avatar
    South Carolina
    Re: Recommended TA levels...
    60 to 80 is recommended for SWGs to help combat the pH rise.
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    A lower TA will also reduce the risk of scaling, which is something to watch out for with a high CH.
    BBB "Intermediate Swimmer"
