Thread: got my test kit - adjusting sequence question
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    Just received my K-2006 and tested it out. The past week my water has been looking pretty okay but I've also been 'guesstimating' bleach additions every couple days and brushing the sides down (generating puffs of yellowish-brown dust that I assume are those nefarious mustard algae) so the water is still mostly clear and blue.
    The results:
    FC 0.2 PPM
    CC 0.6PPM
    pH 7.0
    TA 140
    Calcium Hardness 240
    CYA 100+?? (I guess this is why I've had to keep adding chlorine... yes I was using tablets before I joined the forum)
    I just added about 3 lb. soda ash to adjust the pH - can I add the chlorine simultaneously or do I need to allow time for the soda ash to mix in first?
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    Butterfly's Avatar
    South Carolina
    10,045
    Re: got my test kit - adjusting sequence question
    Hi PCMom and welcome
    Allow 30 mins. for the chems to mix before adding the chlorine.
    Also, it would be much better if you used borax to raise your pH as it has little effect on your TA.
    Your CYA is too high, but I think you know that. I suggest a series of drains/refills to get it down to at least 70.
    You're done SLAMing when:
    Aug 2009
    122
    Thanks Butterfly, it's been almost 2 hours since I added the soda ash. thanx for the borax tip too.
    yeah, the drain/refill is a bummer since we're on water rationing here... I'll probably get out the submersible pump so we can at least use the draining water on the garden (assuming that level of CYA isn't a problem for shrubs and lawns)
    Manual vacuum
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It won't hurt anything....What does the rationing mean - are you limited to how much you can drain at a time?
    Jan 2009
    Cupertino, CA
    1,966
    It's not the draining that's a problem; it's the refilling.
    Regarding the CYA test, you can dilute your sample 50/50 with tap water, then double the reading. This will tell you whether >100 means 120 or 180.
    --paulr
    BBB "Intermediate Swimmer"
