Results 1 to 10 of 10
Thread: new cell and temp sensor
    I installed my new cell and temp sensor. The readout on the pool pilot is normal. What is the desired output setting? 15%, 20% Will it set itself?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: new cell and temp sensor
    I would start with the setting that was on the unit before you replaced the cell and sensor and go from there. If i am misunderstanding you, and this is a brand new unit, I set them to 50% at first and babysit the unit till you find a level that best keeps your water within the Cl range you are shooting for.
    Factory Warranty Station for:
    Thank you, my pool is 10 to 12 thousand gallons. I have been running the filter 8 hours a day. Is that good or can I run it less?
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by minivolks
    That depends on a number of factors including surface area of your pool (sq ft), filter type and pump size, distance between pump and pool and so forth. These things basically just tell you how long you need to operate the pump to get 'one turnover' or 10-12K gallons of water through the system in a 24 hour day. More turnovers don't hurt (except, perhaps, your electric bill.)
    Besides turnover, you'll want to monitor your Chlorine and pH (and Alk, CH and CYA less frequently) and water appearance. If you consistently have pristine water, the pH is rock steady but you have excessive chlorine, either dial back the SWG to a lower percentage or reduce pump operation time. Conversely, additional filtering time will result in increased chlorine availability and production, and improved water quality.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    6 to 8 hours a day is fine for right now. You will want to cut back soon (depending where you live) as autumn is coming.
    The pool is shaped like a figure 8. shallow end is 3 feet and deep end is 6. Pump is 20 feet away. I will experiment as you say. I think I can get away with six hours a day. Should I run it in the afternoon, morning, night? I live in sunny central florida.
    It is a Hayward system with a spiral shaped filter system. Solar heat with a Hayward gas heater. There is a hot tub that spills into the pool when the pump is on. It is an elaborate system with multiple valves operating flow and the cleaner. I bought the house last January.
    Now that the new temp sensor and cell have been in operation since this past Wednesday I have noticed the percentage of chlorinating has decreased from 30% to 13% as of this morning. The pool pilot turns the cell on and off. Is the turning on and off normal? I have the water checked weekly at my local pool store. The balance is perfect. The water is crystal clear.
    Also, The pressure gauge in top of the filter reads from 18 to 25. Even with the filter cleaned it reads the same.
    Here is a pic of the pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I would run the pump when the sun is optimal for solar. Providing you are still running the solar.
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    You look like your in Florida.
    Anyway that is a really cool looking pool design.
    This time a year I start reducing my running time and adjust by SWG tdown enough to maintain my FC around 3
    It takes a little testing but I'm sure you can slowly figure it out.
    Iggy in the cool part of Arizona.
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
