Thread: Should I Add More Salt Now, or Wait for Spring?
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    I have an Aquarite SWG. I have the Aquachek salt strips but the readings were always high, and the bar at the top never darkened. So I contacted Aquachek and they sent me a replacement bottle. Today I first tested with the bad batch of test strips and then I tested again with the new batch of test strips.
    Panel reads 3000
    Bad test strips reads 3660
    New test strips reads 2900
    So I'm totally discounting the bad batch of test strips and so my level is 2900 to 3000. Should I add more salt now, or just wait until the spring. We will be closing our pool the week of Sept. 20th and will bringing the water level down below the returns.
    I am getting plenty of chlorine from the SWG and am having no problems at the level it is now.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Should I Add More Salt Now, or Wait for Spring?
    If you're going to remove some water for winterizing, I'd wait until spring when you fill it up again.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    Coastalish 'down easter'
    4,160
    HI Mickey
    Mike is dead right The season is, unfortunately coming to an end , and the unit will produce just fine at ~ 3000
    It would be a waste of money to add more so close to draining water for winterizing.
    Please enjoy the pool for as long as you can this season
    Luv& Luk
    -Ted
    Apr 2009
    S.E. MI
    572
    Thanks so much, guys. The panel read 2800 last night and now this morning 3000. Weird! I guess since it reads salt by TDS maybe that's why such fluctations? I will count on the strip reading of 2900. Anyway, I will wait till next spring to add more salt. You all who live in year round warm climates are so lucky. This summer went by way too fast!
    I really appreciate your help
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Actually, it determines the salt level by measuring the conductivity of the water. I'm pretty sure that's temperature dependent, so it will fluctuate some during the day.
    Always glad to help where and when I can!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Apr 2009
    S.E. MI
    572
    Quote Originally Posted by MikeInTN
    Ahh ha, now that makes sense and would definitely explain the fluctuations, especially since I turned the heater on in the afternoon. Thanks again, Mike
