Thread: Shut pump off?
    Oct 2008
    Yuma, AZ
    33
    Shut pump off?
    I will be leaving for vacation during our "monsoon" season ... in Yuma, AZ "monsoon" equates to wind. The neighbor that usually checks my pool for me is going on vacation also during this time. The wind during the "monsoon" season results in many leaves. etc., in my pool, filling the skimmer basket over a few days. I am looking at my options.
    I have a fiberglass inground pool 20x40 with spa, SWG.
    Question: Is one of my options simply shutting my pump off for the 11 days I will be gone?
    14,000gal IG Fiberglass pool with 850 gal spill over spa, Whisper Flo 1hp pool pump, Whisper Flo 2hp spa pump, DE filter, Zodiac Clearwater LM3 SWG, "Heat Siphon" Model SX5HP pool/spa heater, a water leveler and a Kreepy Krauly cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Shut pump off?
    If you have a cover for the pool, bring the water to shock level and put the cover on. You should still have some chlorine in the water after 11 days and the cover should keep the leaves out. I wouldn't leave the pump on for 11 days without someone to check on it and empty the strainer every day.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Shut pump off?
    It's an option, but probably not the best one
    Being able to cover the pool and keep it running and having chlorine added would be better. Having someone stop by ~every few days to check the pool (with the cover on) would be best
    If there's no one you can get to come by and make sure the pool hasn't started to empty itself, cover it and turn off the pump - a little algae is far better than a wrecked pool and/ or equipment
    Luv& Luk
    -Ted
