Thread: Emptying Pool (boohoo) this weekend.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Emptying pool this weekend, anybody have any idea how long it will take to empty 7000 gal of water through 2 - 5/8" hoses?
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Emptying Pool (boohoo) this weekend.
    I would guess 5 hours or more .... you dont want empty it all the way though !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by TizMe
    The OP has an Intex pool and doesn't leave it up year round.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jun 2007
    MA
    165
    I use a regular garn hose to empty my 15ft intex it takes over 24hrs to empty
    Cheryl
    14X42 Intex Ultra Frame
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    you can use your pool pump which will be much faster, but require you to keep an eye on it to avaoid burning out the pump. Just hook up your vacum and drop it to the bottom of the pool and filter to waste or if you have a cartridge filter, unhook the return line and attach another hose and let her drain in the yard.
    Or without the pump...fill up your vacum hose with water, vacum head attached, drop it to the bottom of the pool and then drop the other end to ground level out of the pool and siphon that way...much faster than garden hoses
