Thread: New Plaster Problem
    New Plaster Problem
    I've got plaster that's a few weeks old that's starting to develop calcium scaling.
    I've been using a nylon brush, but would using a stainless brush do a better job cleaning the walls?
    Also, should I be using some type of chelate to help disolve the scales?
    Thanks for any help.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: New Plaster Problem
    Welcome to TFP.
    Certainly a stainless brush would be better. Calcium scaling is a chemistry issue. You need to test the water or have it tested. Calcium hardness, pH and TA are critical. Problems with these may void your warranty.
    Butterfly's Avatar
    South Carolina
    10,045
    Hey DoinTime and welcome to the forum
    Have you seen the article for start-up of plaster pools? This is a guide. Don't do anything to void your warranty.
    Keeping the pH under control and daily brushing are two major points with start-up.
    If you post a full set of water test results, we could give more input.
    What does your builder say about the problem?
    You're done SLAMing when:
