Results 1 to 8 of 8
Thread: Major crack on Polaris 280 backup valve casing
    Jun 2007
    North Florida
    79
    Hi all,
    There was a thread about a month back about a cracked casing that houses the backup valve on the Polaris 280. It sounded like it was a fairly minor crack.
    In my case, the crack encompasses the entire diameter of the case, except for about 1" Water comes gushing out the cracked opening. This happened within the past day or so.
    Prior to this, I felt the cleaner was operating correctly. We've only had this house and pool for about a month. The pool is about 3-4 years old but the Polaris cleaner was added sometime later, as near as I can figure. I don't know what problems, if any, the previous owners had with this unit.
    My question is what do I replace...the casing alone or the entire "assembly"? And...what would cause this to happen? Anything I need to do to prevent this in the future?
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    Re: Major crack on Polaris 280 backup valve casing
    You can replace just the case. Most pool places may try to tell you they only sell the whole valve. If you can't find the case locally, just go to eBay.
    30K gal. IG Free form
    Cartridge Filter, Solar and Gas Heater
    Using BBB
    Jun 2007
    North Florida
    79
    Thanks CRG...I don't know exactly how that backup valve works and wasn't sure if it got ruined by the crack developing. I like the price of just the casing a whole lot more than the price of the entire "kit."
    Sandy
    If you have time on your hands you can always fix it with AB putty or something similar (JB water weld etc). The pool at my house is 40 years old, so if a part breaks, I either can fix the part or have to purchase a whole new component. It molds very easily and dries over night. Can sand it after with sand paper or dremmel.
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    Jun 2007
    North Florida
    79
    OMG...one of DH's favorite garage/car repair items is JB Weld!!! How funny if I brought home its water equivalent for the pool!! Meanwhile, I just bought the replacement collar on eBay. After seeing the innards of the backup valve, it's probably best I didn't try JB for the first time on that as I would have undoubtedly mucked up all those little plastic wheels inside. May keep it in mind for the next repair, though....thanks.
    Sandy
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Those backup valves are designed to pull the unit out of an area that it has become "stuck" in (of course). Have you ever seen the unit get stuck? Not all pools have areas where the unit can get stuck in. If it doesn't get stuck, Go and buy a swivel (a lot less money) Replace the back up valve with it and see how it goes. If you know your unit gets stuck, you'll probably have to get yours repaired or replaced.
    Update: Sorry, didn't see you already got parts.
    Just a clown talking, ignore him...
    Factory Warranty Station for:
    Help. I have been replacing my entire Polaris 380 backup valve every time the collar cracks which seems to be every couple of years and it just cracked badly again. I think its a design flaw. Just found out I can just replace the collar....duh on me. I want to buy one but I need to know how to get the old one off. There are what looks like thumb print 'grippers' but if it screws off I can't do it by hand. Tried one of those rubber strap wrenches too. Is there some trick to do this? HELP Please
    Thank you
    Terri
    16X37 30,000 GALLON INGROUND GUNITE/ PLASTER MOUNTAIN LAKE WITH DE FILTER BUILT 1987
    There are three swivels on our Polaris hose but it still gets stuck sometimes on the deep end loveseast when climbing and often at the shallow end steps so the back up valve is very useful. I have no experience using a Polaris without the valve.
    Terrib
    Quote Originally Posted by Pool Clown
