Thread: Help Cyanuric Acid in Bottom of Pool
    I read the back of the bottle and did as it suggested, sprinkle on top of the water in the deep end. Now I have Cyanuric acid granules in the bottom of my liner pool. Will this hurt my liner.
    Thank you!
    Donna
    Donna
    18X37 Grecian Vinyl Liner, X-Stream Slide, 1 1/2HP Hayward Pump, 3/4HP Polaris Booster, AquaRite SWG, Jandy AE3000 Heat/Cool, Jandy Deck Jets, 4.0 Colorlogic Light, Polaris 280 Cleaner
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: Help Cyanuric Acid in Bottom of Pool
    not sure about liner damage...it is a weak acid, but nevertheless I see three options
    1) if you have a center drain turn it on and brush the granules toward the drain
    2) if not center drain you can try vacuming...both 1 and two will have the cya settle in your filter, which is fine
    or 3) sweep it around evry few hours so it doesn;t sit on the same spot
    Good luck!
    Jan 2009
    Cupertino, CA
    1,966
    If you do 1) or 2), make sure you don't backwash for a week while the CYA in the filter gets a chance to dissolve.
    --paulr
    BBB "Intermediate Swimmer"
    This is just an update for anyone reading this in the future with the same problem.
    I did push the Cyanuric Acid toward the main drain and I did not end up with any damage to my vinyl liner.
    Thanks for the help, again!
    Donna
    Donna
