Thread: Dimple leak
    Dimple leak
    I had a buddy that patched a hole in the very bottom corner of the deep end. The hole wasn't all tha big but it had left a big dimple about the size of a half a baseball. The patch sucked into the hole and seemed to work okay. This was back in the spring. Now I am losing a lot of water and I have a few clues that it is coming from that general area.
    The edges of that patch have turned loose but most of it looks in tact. Being that it is in a corner it is a little tricky to get a patch down there. The patch is really designed to go on a flat surface.
    How do people handle this that know what they are doing? Unfortunately I don't. Is there some kind of pool bondo that you can pack in the dimple and then patch over that?
    Any ideas will be apreciated. I need to get this thing fixed before it turns cold. I spent all winter last year adding ater over this same leak.
    37000 gallon inground vinyl
    intelliflo 11018
    Pentair 80 sand filter
    3/4 booster with polaris 260
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Dimple leak
    My post in this thread gives the basics of patching.
    With a situation like you describe, I'd TRY to put a patch in the dimple and make it stick - then I'd put a patch over the dimpled area (~ 1" larger than the dimple. where the liner is still flat).
    If you need more fro,m me on this, just let me know
    Luv& Luk
    -Ted
