Become a TFP Supporter Pool School
Results 1 to 7 of 7
Thread: light transformer
    light transformer
    Hi,
    I have a Hayward Pro series light 300 watt transformer.
    The problem I'm having is after a couple of hours or days. (it varies) The transformer shuts off.
    To fix it I have to open up the transformer and reset the little white switch (breaker).
    Is my transformer going on me? Any other ideas?
    Thanks
    Scott
    Jun 2007
    SF Bay Area
    441
    Re: light transformer
    scottcostello,
    Welcome to BABC!
    Now a couple of questions:
    1. How long has the transformer been installed?
    2. Is the problem you're having something that has been happening awhile, or has it just started?
    3. If the problem has just started, have you done any changes in equipment or operation recently?
    4. What exactly is the transformer feeding? Number of items and each items wattage would be very useful.
    Is this the transformer that you have? http://www.haywardnet.com/products/M.../manual185.pdf
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Thanks very much for the quick reply
    The pool is about 4 years old.
    I'm not sure, we just bought the house, it's been happening since we moved in.
    The only thing I've done was put a timer on the pool house outdoor lights which is on the same circuit, however,
    the problem was there before that.
    It's feeding the two pool lights and that's it. Sorry I have no idea what the wattage of those lights are.
    Is this the transformer that you have? http://www.haywardnet.com/products/Manu ... ual185.pdf
    different model number but it looks like it and has the same breaker switch etc. My model number is TR300R or TR3604R they
    are both on it.
    Again thanks
    scottcostello,
    1.
    Jun 2007
    SF Bay Area
    441
    Scott,
    I don't have a transformer on my pool lights, and the Hayward manual was not very useful. The manual didn't even mention the switch you are talking about.
    I'm a little confused. You said that the transformer will work for a couple of hours or days, but are you running your pool lights for days at a time? How exactly are you seeing the transformer failure - are you turning on your pool lights and then at some point they go out? Or are you trying to turn on your pool lights and then find out that the transformer isn't working?
    Do you have access to a clamp-on electrical multimeter?
    I agree about the manual and the staff at Hayward, neither were very helpful. All the Hayward people kept telling me
    was to resync the light. Turn it on and let it resync. Once I told them it's not a sync issue as soon as I hit the breaker/switch button
    the lights come back on with no issues they were at a loss and put me on hold until I hung up (20-25mins)
    As for the lights it's a bit of both. When I reset the breaker they will work for a bit and either fail after an hour or two or work
    for a few days, off during the days and on in the evenings for an hour or two.
    No I don't leave them running or have a timer it's all either through the remote or the
    switch on the front of the transformer.
    I've sent Hayward an email asking them what transformer replaces this one!
    This is my first pool so when you say you don't use a transformer how do you turn your
    lights on. Normal house power and switch?
    Do I need a transformer?
    Thanks
    Scott
    Could there be a surge when the other timer kicks on that is tripping a GFI?
    Jun 2007
    SF Bay Area
    441
    scottcostello said,
    I have a 30 Amp, 120/240 Volt feed from my house panel to a pool panel (located in the Aqua Logic electrical enclosure). A 15 Amp GFI breaker then feeds the pool light and spa light. There used to be exterior switches that controlled the two lights individually. Now the two lights are turned on and off via 120 Volt relays in the Aqua Logic electrical enclosure. The relays are controlled by wireless remotes.
    You need a transformer if your lights are the 12 Volt style.
