Results 1 to 18 of 18
Thread: Black stuff in MA???
    May 2009
    Dallas, TX
    785
    Is this normal? Maybe something has precipitated out? Is the black stuff OK to put in the pool? It is in both gallon containers of MA bought recently from Home Depot.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Black stuff in MA???
    What is MA?
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by stev32k
    What is MA?
    muriatic acid
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    The only thing I can think of that would be black is carbon particles. I don't know if it's OK to put in the pool or not, but if it were me I would return them to HD and find some jugs that didn't have the black stuff - maybe at Lowes.
    Butterfly's Avatar
    South Carolina
    10,045
    I don't know, either, but I would return it.
    You're done SLAMing when:
    May 2009
    Dallas, TX
    785
    Huh, guess I will return it then. That way I won't have to ask y'all how to dispose of it safely. That was going to be my next question! :P
    It's kind of weird, because I used about a quart of one of the gallons before noticing the particles. Then I immediately opened the other one, and they were there too.
    Hope HD will take it back without a receipt... I'm not sure I want an exchange, because how would I tell if the rest of the pallet was contaminated as well?
    Butterfly's Avatar
    South Carolina
    10,045
    "Refund, please." If no, then store credit
    May 2009
    Dallas, TX
    785
    Just an update: Got a full refund from Home Depot, so took that money over to Lowe's and purchased 2 contaminant-free gallons.
    But I'm curious...has no one else ever ran into this problem before? Black particulate matter in muriatic acid? Looked like someone put a handful of dirt in each gallon jug...
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I haven't and I've handled a lot of muriatic and hydrochloric acid (muriatic is just a poor grade of hydrochloric). You will frequently see yellow muriatic which is caused by iron contamination, but I don't believe I've ever encountered black particles.
    May 2009
    Dallas, TX
    785
    Really? I think most of the MA I have bought around here is yellow(ish)! Could the black particles have been iron??? They remained in suspension when mixed...I can't help wondering if I was just the "lucky" one or if the entire pallet at HD was contaminated...
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    The MA will completely dissolve iron, or rust and turn the solution yellow so iron is not a likely candidate. Your black particles could have been any one of several things like carbon or some organic carbon containing compound or it could have been some sort of plastic particle - there really is no way of knowing.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    P.S. There is a joke in the chemical industry about how some people think yellow muriatic acid is stronger than clear acid. So for those people the manufacturer will add several nails to a truck load of acid to get the strength up.
    May 2009
    Dallas, TX
    785
    Thanks for taking the time to respond!
    Dave
    So, is using "yellow" MA a source of metal staining on pools?
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by anonapersona
    Could be - depends on how "yellow" it is and how much you add. Pale yellow has a little iron, darker yellow has more, and sometimes it can be almost orange that indicates a lot of iron. It's easy to get a "feel" for how much is present. Get jug that is clear and add a few rust particles or a small tack and watch the color. Then add more tacks or a small nail and watch the color deepen.
    I make it a practice to never buy the yellow stuff if I can tell the color from outside the jug.
    May 2009
    Dallas, TX
    785
    That's the trick though isn't it? Most of what I've bought is in an opaque white container, although the stuff I just bought at Lowe's did come in a clear jug. But they are still packed in a cardboard container that you would have to open first...then what if you found yellow(ish)? Drive to another store?
    I'm hoping there is not enough iron in my yellow jugs to cause any harm. Bottoms up!!!
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    The black specs were most likely from the rubber lining used in HCL storage tanks. HCL will turn yellow if it comes in contact with humid air.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Jan 2009
    Cupertino, CA
    1,966
    I've been wondering about the yellow--the wimpy 14% MA that I picked up from HD one time was as yellow as my 12.5% bleach. My regular MA supply is colorless.
    --paulr
    BBB "Intermediate Swimmer"
