Thread: Sand in pool after backwashing
    cliffstone's Avatar
    Sep 2009
    Killen, AL
    15
    I recently bought a home with a baqucil pool and after converting to chlorine
    changed the sand in the filter. Since then when I rinse after backwashing, there
    is sand in the sight glass. Also when I initially switch to filter (after backwashing)
    there is sand coming out the returns for about 20-30 seconds. Yesterday was the third
    time this occurred. When I changed the sand there was no damage to the laterals
    and the pipe in the middle looked OK. I filled the filter tank about 1/3 full with water
    before adding sand to cushion the laterals. Is this normal after changing sand for a
    period of time or do I have problems? Any advice would be greatly appreciated.
    18x36 IG, 22k Gal, Vinyl, 1HP Hayward SuperPump, 250lb Hayward Sand Filter
    30,431
    Re: Sand in pool after backwashing
    Welcome to the forum.
    Are you using the "rinse" position in between "backwash" and "filter" until the sight glass clears?
    How much sand did you put in?
    cliffstone's Avatar
    Sep 2009
    Killen, AL
    15
    I rinse for about 30 seconds and it is clear except for
    the sand in the sight glass. Should I rinse longer? I added
    250 lbs of sand which is listed on the filter tank.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    you should rinse for about 2 minutes or until there is no sand in the sight glass, before switching back to filter.
    Also...very important, be sure to turn off your filter each time before you change positions on the multiport valve.
    ie.. turn off filter, set to backwash--turn on the filter (wait for clear water to come out the backwash hose)---turn off filter---set valve to rinse---turn on filter---run 2mins or until sight glass is clear---turn off filter----set valve to filter---turn on filter.
