Thread: Bump in Liner from Concrete Underneath
    We had our pool installed in May. We have noticed 2-3 bumps in the liner caused by aggregate sticking out of the concrete below the liner. None have torn through the liner, but they are fairly pointed or sharp pieces of stone. Is this normal? Do PB inspect every square inch of the concrete for smoothness prior to installing the liner? Should I be concerned? Thanks.
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    30,432
    Re: Bump in Liner from Concrete Underneath
    I would say it is a cause for concern if you feel it could pentrate the liner.
    The PB should be notified. Is it on the floor or the walls....those two surfaces are different materials.
    DaveNJ's Avatar
    Toms River, NJ
    520
    I had a similar problem. Under my contract if it was reported in the first year of installation no charge. After one year $300 to drain, pull liner and remove pebble, then install liner.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    They are all on the floor, where the concrete would be. I haven't noticed any on the steel walls.
