Results 1 to 7 of 7
Thread: Taylor test kit and CYA
    May 2009
    Tracy,California
    23
    I am filling the test tube to the top and still can see the black dot...what would that mean my number would be?? Here are the rest of my numbers...Any help about the CYA would be great ....thanks
    FC 3
    PH 8
    TA 120
    CA 250
    CYA 9+ ??
    15k Midnight Blue StoneScape Pebble inground pool and spa
    Pentair clean and clear plus 420 filter 2 Sta-rite 1 1/2 hp pump Raypack 406 heater. TF-100 Test Kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Taylor test kit and CYA
    It means that your cya is below 30 ppm - if the water in the tube is a little cloudy, you have some cya in there (probably below 20) When did you last add cya?
    Luv& Luk
    -Ted
    May 2009
    Tracy,California
    23
    If you mean conditioner ...I put what was left of a pale a few days ago.About half a pale not sure of the ounces.
    Butterfly's Avatar
    South Carolina
    10,045
    Here's a visual on the CYA test that may help. BTW, CYA is also called conditioner or stabilizer.
    This test can be a little tricky to get a handle on.
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by MrDude
    It can take up to 5-7 days for the CYA to fully dissolve and register on tests. Did you add it directly to the skimmer or did you use the 'sock method'?
    May 2009
    Tracy,California
    23
    I added to the skimmer ...I just bought another 4 lbs and added about half. I will test it Saturday and see what it comes out at.
    11,969
    Make sure you leave the filter running while it dissolves and don't clean the filter for a week. It takes 5-7 days for it to dissolve so you should wait until Monday at least to retest.
