Thread: Water Evaporation
    Fayetteville, Arkansas
    220
    Water Evaporation
    That time of year when a lot of evaporation is happening.
    Wonder if there's a calculator for that?
    I'm bringing up the water level to the "right spot" about every third day. There are no leaks. I checked using the 5 gallon bucket method on the steps.
    20x40 30,000 gal IG Liner, Pentair II Sand
    Same deal in my and my dad's pool for the past 2 weeks.
    No calculator... evaporation is dependent on many variables... humidity, cloudiness, wind speed, air temp, water temp, etc.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    It is difficult to get an exact value for a particular day but you can get an average rate from this link. You can improve the estimate a bit by doubling the daily average for summer months and halving it for winter months.
    Mark
