Thread: Sulfuric Acid to Lower PH
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    Went to buy some MA today and they were out at the hardware. Right next to it was Sulfuric Acid for about 20% more in cost and 1/4 the size. I was unable to find the concentration on the bottle. Is it safe to use Sulfuric Acid to lower PH in a pool? Anyone have an idea how much one quart might lower PH in a known pool size versus MA? I realize the strength of what I found is left out...
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    no-mas's Avatar
    Jun 2008
    Re: Sulfuric Acid to Lower PH
    Sulfuric acid lowers pH much the same as muriatic acid when at equal cocentrations. It adds sulfates to the water, though. I wouldn't use it for the long haul, but it's fine in a pinch.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Yep, what no-mas said. For the commonly available concentrations (muriatic at 31.45% and sulfuric at 38.5%) you need just about the same amount to have the same effect. Sulfuric acid adds sulfates (bad), costs more (bad), and doesn't fume the way muriatic acid does (good).
