Thread: My have to move our pool!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Due to our financial situation we may be moving and thus moving our 24ft pool. Is there anything I need to be cautious of when disassembling it? I know the liner will be no good one its emptied and removed.
    Im curious about packing up the filter the most. What care needs to be given to doing this? As well will the walls, rails etc dismantle easy to pack up and move ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: My have to move our pool!
    Lubercate heavily any screws or bolts you can see or get at. Empty the water out of the filter and treat it gently as there is a fragile plastic sand pipe and laterals inside. Mark with a pencil the angles of how the top railing is mounted to the vertical uprights so they can be later reassembled the same way. Take pictures as a history incase you forget of "what goes where"
    When reassmbly comes if you had to deal with rusty screws replace them with SS
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    West Michigan
    108
    Our used pool came to us in 5 gallon buckets marked with how many and what was in them. The side was rolled up and held with a big yellow wratchet strap. Sorry you have to move and move your pool. But I think the greatest part of having a agp is that you can take it with you and you don't have to leave it. Maybe your next liner can be something even better? Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Ziploc bags are great for keeping screws, bolts, etc. together. If you can find some that has a place to write on the outside w/ a Sharpie, that's a bonus, too. Otherwise, just write down what they go to on a slip of paper, and put that in the bag as well.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
