Thread: algae
    Jul 2009
    Newnan, Georgia
    24
    algae
    I'm not sure if it is algae or not.We are having a deck built and it could be saw dust.We haven,t been in the pool in a week
    but I test the water every day.FC has been 4.5 CC 0 PH 7.5.We have had alot rain .How can I tell if it is algae with out getting in?The water is crystal clear.THX
    25.6 K Gallon , 33' Round AG
    ProClean Cartridge Filter 125sf
    2 hp, 2 spd, 115 volts, 11.0 / 2.9 volts Waterway Pump
    Well water
    Butterfly's Avatar
    South Carolina
    10,045
    Re: algae
    You can do the overnight FC loss test to rule out organics/algae.
    You're done SLAMing when:
    Jul 2009
    Newnan, Georgia
    24
    Re: algae
    How do I do an overnite FC loss test?
    Well water
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: algae
    Click on the words "overnight FC loss test" in Butterfly's post and it will take you to the pool school section with instructions how to perform it.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
