Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 82
Thread: Refinishing / Restoring a Fiberglass Pool Slide
  1. Back To Top    #21
    Re: Refinishing / Restoring a Fiberglass Pool Slide
    They have the best recommendation for refinishing a pool slide. It is just like the outdoor play set that capable to restore the texture of the slide. It's better to know the process identification of the slide so that you know how to restore it.
  2. Back To Top    #22
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    OK. We sanded down the slide which made a huge difference. Still have to take some pic's. We have a few chips to repair and then another sanding and cleaning. I ordered the Interlux perfection
    (after talking to our marine supply store). Depending on the weather we should be able to finish it out in a week or so.
    18X36 IG, vinyl with 3/4 HP Hayward sand filter, 25K gallons. Six person hot tub.
  3. Back To Top    #23
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    Hey-
    Here are pictures from our slide refurbishing. We used the Interlux Perfection. It took about 2 days for prep with sanding, bondo and waiting for the weather. We have one more coat to put on. The paint is a little tricky to use but not bad. We bought one quart (68.00USD) and that is plenty. It takes approximately 4 hours to dry to the touch and 14 hours to overcoat which means if your slide is exposed (as ours is) you have to have some good weather. We did have a couple of bugs land in the wet paint but it didn't hurt the finish. The bugs didn't fare so well however.
    It does look like we have a new slide!
    [attachment=2:12i6y4o6]IMG_2473.JPG[/attachment:12i6y4o6]
    Slide sanded and halfway prepped
    Another shot
    [attachment=1:12i6y4o6]IMG_2464.JPG[/attachment:12i6y4o6]
    [attachment=0:12i6y4o6]IMG_2467.JPG[/attachment:12i6y4o6]
  4. Back To Top    #24
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    Here are some shots after the Inerlux.
    [attachment=2:2r2mp624]IMG_2483.JPG[/attachment:2r2mp624]
    [attachment=1:2r2mp624]IMG_2480.JPG[/attachment:2r2mp624]
    [attachment=0:2r2mp624]IMG_2486.JPG[/attachment:2r2mp624]
  5. Back To Top    #25
    That looks just beautiful!
  6. Back To Top    #26
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,093
    Wow! that looks amazing....
  7. Back To Top    #27
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Wow that is awesome it looks brand new!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
  8. Back To Top    #28
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Holy cow, thats absolutely amazing!
    Has your daughter given it her stamp of approval yet?
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
  9. Back To Top    #29
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    Well, we sanded down any imperfections and put an overcoat on and we have a couple of spots that are a little duller than others. That is mostly at the top of the slide which may be due to the dew we had during the night. It did turn out really well and we are going to buff it out and wax it for protection. Not sure which wax but definitely a boat/marine wax. We had to order the sprayer nozzels for replacement. The parts were for a Smith slide even though we are not certain that is the brand of our slide but they fit just fine. Word of warning...for two small plastic nozzles and 100 foot of tubing it was 60.00 USD. Although, it was much cheaper than replacing the slide I thought the cost for the silly little nozzels was ridiculous. But all in all it cost us about 120.00 USD. Not bad for the results.
    BTW I really appreciate the video's that were posted from Interlux. They were SO helpful to make sure we did everything right. This site is wonderful! thanks for all the insight.
  10. Back To Top    #30
    Thank you for sharing this. We've a slightly cracked SR Smith Frontier III and can't find a replacement anywhere. Not that I really want to spend $1000 on another slide that is rarely used. I stumbled on to your posting and must say I'm inspired. Phenomenal job!
  11. Back To Top    #31
    I need to replace the water jets and tubing on my slide I'm in the process of refinishing. It's identical to the one in the pictures above. I've repainted using the Perfection paint and it looks great. I used the platinum color to match our pool deck. I'm about ready to reassemble and reattach to the pool.[attachment=2:15aq2shf]photo.jpg[/attachment:15aq2shf]
    1) The size of pool in gallons = 30,000
    2) The type filter you have =sand
    3) Pool is an IG (in ground)
    4) IG = vinyl
    5) Don't know size of pump and the size (flow rate) of filter yet, will try to find out.
  12. Back To Top    #32
    Latest pictures of installed refinished slide. Waiting on water jets and tubing which should arrive this week. I know my grandkids cannot wait to try it out; of course, Papa will have to give it a test run, too!
    4) IG = vinyl
  13. Back To Top    #33
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    That looks great! I love the color...
  14. Back To Top    #34
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    All you DIY'ers have done beautiful jobs on your slides!
    Me, I'm not so much of a DIY'er. I took mine to a local independent body shop. I figured that if they could repair Corvettes, they could repair a fiberglass slide. Did a great job. Cheaper than a new one, more expensive than DIY.
    BTW, the water nozzles are available at Leslie's pretty cheap. I picked up the hose at HD, much cheaper & better quality than the OEM stuff.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
  15. Back To Top    #35
    Panther's Avatar
    Apr 2010
    Lansing MI
    13
    Wow, never even thought of taking ours to a body shop...what a great idea!! That is how I figured out how to refurbish it though. I figured if you can repair the fiberglass on a corvette, a slide should be pretty simple. I just never thought to take it to a shop. Duh!
  16. Back To Top    #36
    CUTiger78.....if u don't mind me asking.....how much did the body shop charge? BTW...I'm CU Class '80 & wife just retired from CU last week.
    4) IG = vinyl
  17. Back To Top    #37
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by DIYSELF&SAVE
    ...how much did the body shop charge?...
    If I remember correctly (it was 10 or 12 years ago) it cost $600.
    TF-100 test kit.
  18. Back To Top    #38
    CUTiger78....Thanks! How's the paint holding up on the refinished slide? How 'bout dem Tigers?!
    4) IG = vinyl
  19. Back To Top    #39
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    ... How's the paint holding up on the refinished slide? ...
    Holding up great! All I've ever done is wash it. I think that this year I'll polish and wax it with a good quality car wax.
    Clemson v. Alabama in the Super Regionals Friday on ESPNU!!
    TF-100 test kit.
  20. Back To Top    #40
    Good thread here. I'm getting ready to refurb an old Aquaslide which has seen better days. Fully intend on using Interlux Perfection as mentioned in the above posts. Here's my question.
    I'm going to have to be creative in my placement, since I have a sport pool, and this pool is not really meant for a slide, but should work, given the specifications from SR Smith. As for the plumbing.....I obviously have no dedicated return for water supply for the slide. Is it possible to put a threaded tee on the closest return? Put the eyeball on the end of that tee, and then run flex up to the slide? Water pressure issues?
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
