Thread: DIY Solar Pool Heater Idea
    I am looking at building a simple, CHEAP, solar heater for my ABG pool. But I am no genius when it comes to fluid dynamics. I plan to install a valve on my current 1.5" PVC in order to shunt it off to multiple half inch poly tubing (used for drip irrigation).
    Could I just use a PVC manifold
    add adapters to connect 100' of tubing to each, and another manifold on the other end to send to the pool? That's a lot of distance to push fluid, right? Or should I have more but shorter runs?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: DIY Solar Pool Heater Idea
    You'd get very poor efficency. What you want are many, many very small tubes to maximize water contact with the tubes.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Until this year we were using the same diameter pipe for our solar system. The only difference was that the pipe was enclosed inside a box with a lid made out of old slide glass doors. It worked fine, just make sure you use a solar cover as well and have a valve to control the flow to the solar pipe.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Quote Originally Posted by JohnT
    I know. But I cannot think of a material that will do that other than a commercial kit.
    Quote Originally Posted by X-PertPool
    I plan to have box with a radiant barrier on the bottom, then black plastic, the tubes, and topped with window glass.
