Thread: Texas pool
    Texas pool
    I've posted a few times asking for help, figured I'd should share some photos. Pool is 4 years old, owner built/designed (we own a construction company), dark gray plaster, 60K gallons, SWG (which isn't working right now), native limestone, trying to survive this drought at the moment. Most photos from last summer, water isn't looking this clear currently.
    18 x 38 - 28,000 gallon vinyl in ground built in 1998, Sta-Rite cartridge filter and heater.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    Re: Texas pool
    Pretty pool and back ground
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Aug 2009
    Hattiesburg, MS
    Re: Texas pool
    Now this is one for the books. GREAT JOB!!
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
    Pisces's Avatar
    Jun 2008
    League City, Texas
    Re: Texas pool
    That's a beautiful pool and location!! I really miss Central Texas...good luck with the drought conditions, though. It's been tough, I know.
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Butterfly's Avatar
    South Carolina
    Re: Texas pool
    Beautiful pool and surrounds
    You're done SLAMing when:
    Re: Texas pool
    That really is a beautiful pool!
    10,000 gallon in-ground pool, Jandy AquaPure 1400 SWG, Jandy Purelink Water Purification System, AquaLink RS Pool Digital Assistant, Jandy Stealth Series Pumps, Polaris 380, 3/4 hp booster pump, DE Filter, Lucayan Blue River Rok aggregate innerds
