Results 1 to 9 of 9
Thread: Chlorine Free pool
    Guest
    Chlorine Free pool
    Hi. Has anyone used the Revacil Program, Chlorine Free pool Sanitizing. I've been using the baquacil but is more expensive. Any suggestions and/or advise.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Chlorine Free pool
    Most of everyone on here is going to recommend you switch to chlorine (myself included )
    Any reasons you haven't been using chlorine?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jan 2009
    Cupertino, CA
    1,966
    Revacil looks like it's another form of biguanide, same as bacquacil. You should check out the recommended doses and see how the price-per-dose works out, to see if it really cheaper.
    Or... convert to chlorine!
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by X-PertPool
    What Kevin said
    BBB should really read CCC (Chlorine, Chlorine, Chlorine)
    Aug 2009
    Keene, Texas
    157
    I used revacil and revatop 36 in conjunction with the baquacil products until I started converting. As far as baquacil products go, it was a good product, but you still have the same baquacil issues. I spent over $1200.00 this summer on these products and was fixing to drain my pool and tear it down because of the cost of chemicals. Praise God, I found this website to show me how to keep my pool crystal clear for much less. If I were you I would convert to BBB.
    amoses (Aaron)
    Converted from Baquaqoo in the fall of 09. Best thing I ever did!!
    AG, 24 Ft Round, 54" wall, 48" deep, 13,500 gal., TF-100 test kit
    Hi-Flo II 1.5 HP pump, AquaTools High Rate 200# Sand Filter AT3120
    Sep 2008
    The Woodlands, Texas, USA
    243
    Baquacil can be dangerous to your health as it's ability to sanitize degrades over time. Eventually you will struggle enough with algae blooms that you will be back here converting to chlorine like everyone else has.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Convert, convert, convert!
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Aug 2007
    near the swamp
    806
    I carry Revacil and don't even recommend it to my customers.
    Guest
    Would like to thank everyone on their comments and suggestions. In the spring I'll be converting to chlorine. It's either that or my better have will be filling the hole in with dirt. lol
