Thread: Fine particles
    Jul 2007
    Michigan,
    18
    Fine particles
    Hi, for the last 3/4 weeks now I have what appears to be very fine particles of greeny browny dirt or the like at the bottom of my pool, my pool rover cleaner is working well I think, my water balance is within range.When I brush it up you can see the water is in good shape by the crystal clear colour, but then it settles down and the pool cleaner will not lift it. I'm thinking of getting some of that super floc to make the particles bigger to enable the rover to lift it
    What do you guys think any help is welcome.
    Ps if this is the right solution how much will i need ?
    14500 gl, oval, vinyl
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Re: Fine particles
    Just because the water appears clear, does not mean that all is good.
    I would try manually vacuuming before adding anything to the water. In pools, less is more. You don't want to add anything that is not 100% necessary.
    What are your pool numbers?
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    Jan 2009
    Cupertino, CA
    1,966
    Re: Fine particles
    Hear hear; you probably want to try an Overnight FC Test to make sure it's not organic.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2008
    Central MD
    149
    Re: Fine particles
    Do you have a DE filter? If so, have you verified there are no holes in the grids? Sounds to me like DE.
    The Overnight FC test mentioned above will tell you if it's algae or not. If test shows no overnight FC loss, bet you a douoghnut it's DE.
    24' Round Doughboy AG.
    Usually filled with 3 kids, the wife, and occasionally the dog.
